gauge cluster..please help
Old Apr 22, 2008 | 04:05 PM
99r/tneon's Avatar
99r/tneon
Default gauge cluster..please help
have'n some problems with my gauges. one min they will work perfectly fine. the next they wont work at all. the next everything will work except the speedo. then sometimes they quit working and the lights will dim and both my turn signal lights will come on (only on the inside, not on outside). then if you punch the top of the dash or push on the lens of the gauges they will sometimes start to work again. i know it isn't in the cluster because i replaced it like 5 times. please help.
Old Apr 22, 2008 | 04:18 PM
rockenuptown's Avatar
rockenuptown
Default RE: gauge cluster..please help
check the fuse
Old Apr 22, 2008 | 07:01 PM
12 volt's Avatar
12 volt
read this
https://dodgeforum.com/m_179505/tm.htm
Old Apr 22, 2008 | 09:43 PM
99r/tneon's Avatar
99r/tneon
ok..but i changed my cluster like 5 times. what are the chances of all 5 have'n this problem? i guess it might be in the plugs that are in the dash..
Old Apr 22, 2008 | 09:46 PM
das2123's Avatar
das2123
It is pretty common, so it is possible. Did you reflow any of the connections?
Old Apr 23, 2008 | 06:50 AM
99r/tneon's Avatar
99r/tneon
nah. i jus took the old out and put the new in.
Old Apr 23, 2008 | 08:31 AM
das2123's Avatar
das2123
ORIGINAL: 99r/tneon
Do the soldering thing to all of them and then sell them
Old Apr 23, 2008 | 11:43 AM
Tweaked_Neon's Avatar
Tweaked_Neon
check the data cable going into the back of the cluster, i know mine was messed up
Old Apr 23, 2008 | 12:59 PM
99r/tneon's Avatar
99r/tneon
how do i know which one the data wire is? and the selling ideais anawesome idea jus might have to do that! haha i have alot of them
Old Apr 23, 2008 | 01:08 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Mine does that alot. All I do is give it a nice firm push. Make sure the plugs are in. Works everytime.
