i would put a AF/x or mopar in.. correct me if i'm wrong but i believe the mopar speed limiter is 149 and the AF/x isn't limited at all.. not sure though.
you could put a switch on watevr of the 3 wires so you can shut off your vss at watever speed you want to get above.. thats waht i would do if mine worked. but the synchros in my trans are going bad so my vss should be fixed when i get a new trans[8D]
