FOAM IN THE COOLANT
Old Apr 23, 2008 | 12:07 PM
mcss8541's Avatar
mcss8541
Default FOAM IN THE COOLANT
I changed out that pain in the *** radiator last night and filled it with new 50/50 premix fluid and through in a bottle of a coolant additive for good measure. I was debating on changing out the thermostat but since I had it tore down I went ahead and did it and thank God i did because the one that was in there had broken apart. The bottom part was in the neck the spring was on top if it and was holding up the " Flying Saucer" looking top. When everything was buttoned up and filled I started the car to get the air bubbles however instead I got a bunch of little ones almost looking like bubble bath. Is this normal or could it be from the additive? Also it took a while for the thermostat to open up as a matter of fact the fans came on and the top rad hose was still cool to the touch.
Old Apr 23, 2008 | 01:37 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: FOAM IN THE COOLANT
It could be the additive, but usually when you get lots of little bubbles, it means the water pump is bad.
