200hp!!
Old Apr 26, 2008 | 11:57 PM
just8420's Avatar
just8420
Default RE: 200hp!!
well what i really wanna do is beat up on my buddys G.L.I. mostly stock puts around 205 to the wheels so you think a turbo would be the only way
Old Apr 27, 2008 | 12:00 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: 200hp!!
not the only way, but prolly the easiest and cheaper way... just my two cents....
Old Apr 27, 2008 | 12:02 AM
95to96transplantneon's Avatar
Default RE: 200hp!!
ok so if its that easy to get 200hp on a sohc why has only 2 guys done it??? NA that is...
Old Apr 27, 2008 | 05:14 AM
JackMehoffer69's Avatar
JackMehoffer69
Default RE: 200hp!!
ORIGINAL: 95to96transplantneon
what costs $10,000 thats what I want to know. I thinlk a hemi crate engine is close to $10,000 for 550hp.
pistons and Rods $800 Block and crank work $300 head work $200 plus $300 cam, intake $200, 60mm throttlebody $200,mopar pcm $150. Hell if you wanted put a sohc head on a 2.4 block I'm basing these off of what I put into my turbo dohc at Car QuestAuto Parts and Machine shop.Thats about what all the machine work costed and slash and my dad helped mebuild the motor, the only thing is i don't have a mopar pcm.
The only thing that would suggest expensive would be nitrous or professional turbo with injectors.
i'm nottrying to insult you in anyway 9596transplantneon i just think $10,000 its 2/3rds higher than it really is to build a 200-250hp motor.
Old Apr 27, 2008 | 02:49 PM
12 volt's Avatar
12 volt
Default RE: 200hp!!
iam looking to try to pull 200hp out of my sohc mtx is that a reasonable goal and what kindda mods would i need i plan on keeping n/a for now due to $$$$ or if i could find a cheap turbo i would put it on but seems a bit out of reach right now so any help would be great by the way its bone stock right now
best thing you could do is swap to a 2.4 much easyer to hit 200+ that way
so what your trying to say is that you have an engine that will put 200 hp down, and you not even using it.
Old Apr 27, 2008 | 05:10 PM
JackMehoffer69
Default RE: 200hp!!
ORIGINAL: 12 volt
its in the car but I'm waiting on the PT clutch to arrive. the only difference is my motor is turbo charged and pretty much the keith blackpistons i gotare 8-1 and were close tothe same price as the 12-1 option so you could build a convincing motor for not very much difference than a turbo motor. the difference between NA power and turbo power is the compression and of course the turbo itself
Old Apr 27, 2008 | 06:09 PM
12 volt's Avatar
12 volt
Default RE: 200hp!!
its in the car
what car?
Old Apr 27, 2008 | 06:47 PM
JackMehoffer69
Default RE: 200hp!!
ORIGINAL: 12 volt
its in the car
what car?
um my baby which is my red99 Neon Sport
Old Apr 27, 2008 | 06:58 PM
12 volt's Avatar
12 volt
Default RE: 200hp!!
ORIGINAL: JackMehoffer69
ORIGINAL: 12 volt
its in the car
what car?
do you have two neons?
Old Apr 27, 2008 | 07:16 PM
JackMehoffer69
Default RE: 200hp!!
ORIGINAL: 12 volt
ORIGINAL: 12 volt
its in the car
what car?
Yes, my wifes highline and my Sport Neon the wifes Neon is actually in my name but i call it hers because she uses it to do everything. I also have 2 parts neons i might be selling soon as well, a 2 door and 4 door both are dohc.
