2.4 SWAP HOW TO... NOT DONE 56K Take a nap...
Old 12-12-2012, 01:36 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
Originally Posted by bdiggity
Question, if you don't fill the oil passage after removing the balance shaft assembly, wouldn't the oil just dump into the oil pan? Where is the problem, or am I misunderstanding? Also, your trick with swapping the pins on the wiring harness is genius. Excited to see how all turns out with my little project car.
Yes. This is correct.
Quick Reply: 2.4 SWAP HOW TO... NOT DONE 56K Take a nap...
