FS: low mielage engine block. *pics*
Old Apr 28, 2008 | 11:23 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Default FS: low mielage engine block. *pics*
Found this 98 sohc engine almost two years ago. Sold the head, but kept the gauge cluster and the block, flywheel, oil pump, pistons, rods, and the crank.
Would like to sell it complete with some dohc pistons and a 420A oil pan. Would be great for a dohc or sohc car. $250 p/u I am going 2.4, and this block has no place in those plans. This is one of the cleanest parts i have. No leaks at all.[/img]
Old Apr 28, 2008 | 01:36 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: FS: low mielage engine block. *pics*
Where you at? its a dohc? And it runs clean? PM me. I wont check this.
Old Apr 28, 2008 | 02:08 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
is it a stock block? or built? if it is a built block out of a sohc pm me!!!! would be very interested if so
Old Apr 28, 2008 | 03:14 PM
Ghost Neon 2
It is a stock sohc block. I removed the sohc pistons, and replaced when with stock dohc pistons. Getting new rod berrings and pistons rings, pt water neck, new MLS headgasket and head bolts for $500 p/u. This block ran smooth, and is clean as hell from the engine pulls. I have not had it cleaned yet, and really do not need to. Was looking to go with a 2.4 turbo setup, but if this does not sell, I'll be dropping into my current neon.
