Has anyone ever used both the 3.94 and the 3.55????
Old May 2, 2008 | 09:41 PM
  #31
neonracer1010's Avatar
neonracer1010
Default RE: Has anyone ever used both the 3.94 and the 3.55????
95-96 do u still need that arm?????
Old May 3, 2008 | 12:22 AM
  #32
95to96transplantneon's Avatar
no sorry... figured out an easy fix...
Old May 3, 2008 | 12:28 AM
  #33
Well I got it in and going... now I have to find out where the damn trans is leaking... I think its just overflow coming off the trans from when i filled it... but then again my chain bolt broke sending the tranny falling to the floor from about 2 feet up... hope its not cracked... I like it... no more jerking...
Old May 3, 2008 | 02:57 AM
  #34
boxerjl2's Avatar
boxerjl2
so hows that new trans going for you Jeremy?
Old May 3, 2008 | 01:14 PM
  #35
boxerjl2's Avatar
boxerjl2
haha oops i didnt see your post.. i hope the leak isnt anything bad.. i hope its just some overflow like you said well keep us updated...
and im sure its 10x better then when i drove it [8D].. now you just need to fix the radiator support
Old May 3, 2008 | 02:14 PM
  #36
12 volt's Avatar
12 volt
anyone have some part #s for these ratiosfor identification purposes?
Old May 3, 2008 | 11:16 PM
  #37
Part numbers...
95-99 sohc 3.55 0.72 5th gear= 4670235
95-99 ACR, 95 DOHC, 98-99 R/T 3.94 0.81 5th gear= 04670234AC
96-99 DOHC (non-ACR, R/T) 3.94 0.72 5th gear = 04670664
Old May 4, 2008 | 03:49 AM
  #38
boxerjl2's Avatar
boxerjl2
WERE ARE THOSE LOCATED.... i can only see one line of numbers.. ill go right them down and see what i can see
Old May 4, 2008 | 04:13 AM
  #39
boxerjl2's Avatar
boxerjl2
ok well i found 3 differant lines of writing and it located were the shifter cables hook up
first
26098
second
C-26099 A (the A is circled)
Third
21284852
those may not all be correct cuz its 2:17 and i had to use the flash from my camera to see it
so were are the numbers located.. cuz these one were right buy the booger bushings
Old May 4, 2008 | 04:21 AM
  #40
boxerjl2's Avatar
boxerjl2
the picture is blurry but thats were they were located
[IMG]local://upfiles/60625/5AC07DC0117F4BD98B4DD417A4533913.jpg[/IMG]
