2.4
Old May 2, 2008 | 12:30 PM
93 tona's Avatar
93 tona
Default 2.4
really quick, what is the best flywheel to use,iam swapping in a 2.4 and a manual trans at the same time,i know i need the 2.0 dohc manual one, but does it matter if it is a compound clutch or individual disc clutch, and can i use one say out of a PT cruiser for added horse power... basically,if i walk into a junkyard, to which car would you point me...
Old May 2, 2008 | 01:35 PM
95to96transplantneon's Avatar
Default RE: 2.4
Either willl work with the same result... there are more options with the non-modular however you will spend more in the end...
Old May 6, 2008 | 12:46 PM
93 tona's Avatar
93 tona
Default RE: 2.4
can i just use the 2.4 flywheel it was out of a 96 dodge stratus with an automatic, and can i cut any spots out of it to lighten it up with out loosing structural support. has this ever been done
Old May 6, 2008 | 03:12 PM
neonracer1010's Avatar
neonracer1010
Default RE: 2.4
unless your going to be cutting it with a cnc mill or anything that is extremely precise, i wouldnt cut it because then it would be out of balance and it will break after a while
Old May 6, 2008 | 06:49 PM
Default RE: 2.4
no it will not work its a different clutch size...
