Miss fire in Cylinder 2
Old May 2, 2008 | 01:31 PM
krtrsdg0's Avatar
krtrsdg0
Default Miss fire in Cylinder 2
Ive replaced plugs wires coils computer does and one no wut it could be cause i have no idea?
Old May 2, 2008 | 02:09 PM
95to96transplantneon's Avatar
Default RE: Miss fire in Cylinder 2
injectors are probally clogged...
Old May 2, 2008 | 02:14 PM
Try soaking the injectors in dieasel fuel... clean em right up...
however concidering that dieasel is 4.21 a gallon you may want to look into some carb cleaner...
Old May 2, 2008 | 02:15 PM
sparky3009's Avatar
sparky3009
Not sure if you have a haynes manual, but let your car warm up, then just park it and pop the hood. Unplug injector #1 and see how far the r's drop (just by sound), then put it back in and unplug injector 2 and see if it has the same rpm drop. If so, you either have a bad injector, or like transplant said, its clogged.
Old May 2, 2008 | 03:18 PM
12 volt's Avatar
12 volt
fuel injector problem
