bypassing radiator fan Relay,,,, code 35
Old May 3, 2008 | 07:25 PM
boxerjl2's Avatar
boxerjl2
Default bypassing radiator fan Relay,,,, code 35
would it be possible for the fan to work if i just took out the relay there are 2 black and 2 blue wires going in and out(i believe) so what if i cut the wires on each side and just connected them...without the black little box being there
Old May 3, 2008 | 08:13 PM
neonracer1010's Avatar
neonracer1010
Default RE: bypassing radiator fan Relay code 35
y not just wire it in so it comes on with a toggle switch?
run wires to the battery then to a switch.
Old May 3, 2008 | 08:20 PM
boxerjl2's Avatar
boxerjl2
that what i did in my cutlass but it looks kinda tacky
i dont know i got a diff fan with the relay on it so ill see what happens when i hook it up i was just curious if the fan would work without the relay
Old May 4, 2008 | 10:27 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Default RE: bypassing radiator fan Relay,,,, code 35
It will not work. What year is it?
Old May 4, 2008 | 04:20 PM
boxerjl2's Avatar
boxerjl2
my car is a 98..
well i decided to just hard wire it to a toggle becuz,,, the other relay i have came off my 96 and they are not the same....
so i just hard wired it
Old May 4, 2008 | 04:27 PM
Ghost Neon 2
I need to do mine.
