how to check tranny fluid
Old May 5, 2008 | 08:29 PM
spp's Avatar
spp
Default how to check tranny fluid
i been look around the tranny check the fluid to c if i need any and i dont no where to look 4 it at someone help
Old May 5, 2008 | 08:48 PM
TubbyCheekers's Avatar
TubbyCheekers
Default RE: how to check tranny fluid
Your Tranny Dipstick or The Tranny check tube should be located on the drivers side of the motor between the air intake and the power fuse box with large and small fuses -(Power Distribution Center)
Old May 5, 2008 | 08:52 PM
neonracer1010's Avatar
neonracer1010
on the drivers side of the tranny, theres a little black plug on mtx pull it off and stick ur finger in there, if its about level with the hole ur good
Old May 5, 2008 | 10:25 PM
spp's Avatar
spp
thanks
Old May 6, 2008 | 06:53 PM
spp's Avatar
spp
the dip stick is under the fuse box and if so wat is the best trans fluid i can use
Old May 6, 2008 | 07:50 PM
95to96transplantneon's Avatar
atf+4 DO NOT MIX DIFFERENT BRANDS...
Old May 6, 2008 | 08:29 PM
spp's Avatar
spp
cool
Old May 7, 2008 | 08:26 AM
das2123's Avatar
das2123
ATX has the dipstick...MTX has the rubber plug to check fluid levels.
ATX should use ATF+4, MTX can use Redline.
Old May 7, 2008 | 09:29 AM
spp's Avatar
spp
light weight r heavy weight
