check engine codes
Old May 8, 2008 | 03:39 PM
loud99R/T's Avatar
loud99R/T
Default check engine codes
my 99 r/t is throwing a code 72? as far as i know code 72 does not excist? i've done it twice and still get the same thing
is there a more in depth code list that goes past 65?
Old May 8, 2008 | 04:13 PM
95to96transplantneon's Avatar
Default RE: check engine codes
Key Dance = On - Off - On - Off - On within 5 seconds
11
P0320 No Crankshaft Reference Signal At PCM
P1390 Timing Belt Skipped Tooth
P1391 Intermittent Loss Of CMP Or CKP
P1398 Misfire Adaptive Numerator At Limit
12
Battery Disconnected
13
P1297 No Change In MAP From Start To Run
14
P0107 MAP Sensor Voltage Too Low
P0108 MAP Sensor Voltage Too High
P1496 5 Volt Supply Output Too Low
15
P0500 No VSS Signal
16
P0325 Knock Sensor Circuit
17
P1281 Engine Cold Too Long
P0125 Closed Loop Temperature Not Reached
21
P0131 Upstream O2S Shorted To Ground
P0132 Upstream O2S Shorted To Voltage
P0133 Upstream O2S Slow Response
P0134 Upstream O2S Stays At Center
P0135 Upstream O2S Heater Failure
P0137 Downstream O2S Shorted To Ground
P0138 Downstream O2S Shorted To Voltage
P0139 Downstream O2 Sensor Slow Response
P0140 Downstream O2S Stays At Center
P0141 Downstream O2S Heater Failure
22
P0117 ECT Sensor Voltage Too Low
P0118 ECT Sensor Voltage Too High
23
P0112 IAT Sensor Voltage Low
P0113 IAT Sensor Voltage High
24
P0121 TP Sensor Signal Does Not Agree With MAP
P0122 TP Sensor Voltage Low
P0123 TP Sensor Voltage High
25
P0505 IAC Motor Circuits
P1294 Target Idle Not Reached (+/-200 RPM)
P1299 Vacuum Leak Found (IAC Fully Seated)
27
P0201 Injector Circuit No. 1
P0202 Injector Circuit No. 2
P0203 Injector Circuit No. 3
P0204 Injector Circuit No. 4
31
P0441 EVAP Purge Flow Monitor Failure
P0442 EVAP Monitor Small Leak Detected
P0443 EVAP Purge Solenoid Circuit
P0455 EVAP Monitor Large Leak
P1486 EVAP Monitor Pinched Hose Found
P1494 Leak Detection Pump Switch Or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circuit
32
P0401 EGR System Failure
P0403 EGR Solenoid Circuit
33
P0645 A/C Clutch Relay Circuit
34
P1595 Speed Control Solenoid Circuit
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
35
P1491 Radiator Fan Control Relay Circuit
37
P0740 TCC No RPM Drop At Lockup
P0743 TCC Solenoid Circuits
P1899 P/N Switch Stuck In Park or Gear
41
P0622 Generator Field Improper Switching
42
P1282 Fuel Pump Relay Control Circuit
P1388 ASD Relay Control Circuit
P1389 No ASD Relay Output Voltage At PCM
P0460 Fuel Level Sending Unit & Circuit, No Change Over Miles
P0462 Fuel Level Sending Unit Voltage Out Of Limits, Too Low
P0463 Fuel Level Sending Unit Voltage Out Of Limits, Too High
43
P0300 Multiple Cylinder Misfire
P0301 Misfire Cylinder No. 1
P0302 Misfire Cylinder No. 2
P0303 Misfire Cylinder No. 3
P0304 Misfire Cylinder No. 4
P0351 Ignition Coil No. 1 Primary Circuit
P0352 Ignition Coil No. 2 Primary Circuit
44
P1492 Ambient/Battery Temperature Sensor Voltage High
P1493 Ambient/Battery Temperature Sensor Voltage Low
46
P1594 Charging System Voltage Too High
47
P1682 Charging System Voltage Too Low
51
P0171 Fuel System Lean
52
P0172 Fuel System Rich
53
P0600 PCM Failure SPI Communications
P0601 Internal Controller Failure
54
P0340 No Cam Signal At PCM
55
DTC Fault Display Complete
61
P0106 Barometric Pressure Out Of Range
62
P1697 PCM Failure SRI Mile Not Stored
63
P1696 PCM Failure EEPROM Write Denied
65
P0551 PS Pressure Switch Failure
P0703 Brake Switch Stuck, Pressed, Or Released
71
P1496 5 Volts Output From Regulator Low
72
P0420 Catalyst Efficiency Below Required Level
77
P1683 Speed Control Power Relay Circuit
Old May 8, 2008 | 09:35 PM
thedark69's Avatar
thedark69
Well you got 4 choice ; Buy a new catback, Destroy everything inside the current one, Replace your catback by a 2' tube(maybe not 2' im not sure), buy a Magnaflow catback or something like that, now you got the choice and don't forget your O2 sensor.
Old May 9, 2008 | 09:34 AM
loud99R/T's Avatar
loud99R/T
with the o2 sensor can i just weld some nuts together and then weld it to the tube? i've heard of being done before but was just looking for a confermation?
