fuel pressure low...
Old May 12, 2008 | 11:08 PM
johnMZ24's Avatar
johnMZ24
Default RE: fuel pressure low...
ok so if i remove the fuel pressure regulator it can damage my engine???? even if i just like drive 5 miles to see if that was the prob? i dont got 200 bucks for a new one.. any idea what i can do...
Old May 12, 2008 | 11:15 PM
95to96transplantneon's Avatar
lol just starting it will mess it up... you would be maxing out the injectors hard core...
Old May 12, 2008 | 11:21 PM
johnMZ24's Avatar
johnMZ24
ahh shizz..... what can i do ta find the prob then...
Old May 12, 2008 | 11:42 PM
put the fuel pressure gauge directly on the fuel line coming off the firewall... in other words disconnect it from the plastic fuel line and hook up the gauge...
Old May 12, 2008 | 11:52 PM
johnMZ24's Avatar
johnMZ24
i cant its a screw in type pressure tester......do u think i need a new fuel pump? cuz it runs fine and all....
Old Jun 26, 2008 | 09:27 PM
kathybrj's Avatar
kathybrj
We're getting ZERO pressure at the Shrader valve on our '98 Neon. We've replaced the fuel pump and regulator/filter. We can hear the pump running and have test pumped gas out of it into a can. But once the tank and all are hooked up to the car, we're not getting any pressure in the system. Ideas?
