intake manifold? exhaust manifold?
Old May 13, 2008 | 01:21 AM
ryleynoyes's Avatar
ryleynoyes
Default intake manifold? exhaust manifold?
so has anyone used any of rternies manifolds? intake or exhaust? i'm interested in buying one, but i want to find out if they are any good before i buy one. i think he's over on the .org site. any other ideas for turbo exhaust/intake manifolds? i'm going to be using a GT3076R turbo
Old May 14, 2008 | 08:55 AM
das2123's Avatar
das2123
Default RE: intake manifold? exhaust manifold?
His manifolds are high quality. So are AMM's manifolds.
Old May 14, 2008 | 12:35 PM
boxerjl2's Avatar
boxerjl2
are there any performance manifolds that you can buy from an actual store? or are they all home made??
Old May 14, 2008 | 01:03 PM
fsu182's Avatar
fsu182
indy from modern if u wanna drop about $500 for one.
http://www.modernperformance.com/pro...c8ec024752e027
Old May 14, 2008 | 01:10 PM
V10's Avatar
V10
I was looking at the Indy last night, looked sweet until I read the 8 reviews every one slamming it and saying it was a waste of money. 8 negative out of 8 total is pretty bad.
Old May 14, 2008 | 02:04 PM
fsu182's Avatar
fsu182
yeah. the custom intakes usually use the upper runners (ported out) and a welded steel box replacing the lower manifold section lower part of the runners. the Throttle body sits vertically - eliminating the 180 degrees the air has to turn to get into the runners.
Old May 14, 2008 | 02:09 PM
das2123's Avatar
das2123
ORIGINAL: fsu182
It sits vertically stock. Aftermarket ones let the TB sit horizontally.
Old May 14, 2008 | 02:35 PM
fsu182's Avatar
fsu182
i meant like the tb itself. to me how it sits is horizontally, but ur right airflow is vertically. srry.
Old May 14, 2008 | 09:36 PM
95to96transplantneon's Avatar
This is my all time favorite pic of a RT ernie manifold...
Old May 15, 2008 | 02:34 AM
boxerjl2's Avatar
boxerjl2
ok well does that one work just as well as AMM's? cuz AMM for all the works wants $550 shipped, so im just curious if they work the same or if AMM's is better.. i would prolly still buy one From Amm just to Support another forum member but im just curious..
