New Vid
Old May 13, 2008 | 08:20 PM
TOOSTUBBORN2FAIL's Avatar
TOOSTUBBORN2FAIL
Default New Vid
Well the car does 15.03, with 90 extra pounds (passenger seat, drivers airbag, an extra radiator since i put on a C&R, and 3/4 tank gas)
this was a handicapped run, car has bald old tires, and it was on an old road that had been tar'd and then pebbled over, so no traction, and the tranny shift forks seem worn out, cause even with the boogers, theres still a lot of play
car weighed 2100 pounds with all that in it, has no ac/ps, Unorthodox racing udp that deletes the ac/ps, pacesetter header, MPx 60mm tb, tb matched intake mani, glasspack exhaust, custom cai, mm inserts, semi-solid bobble strut, booger bushings, bald 3 year+ old tires
soon hopefully cam off a 95', polished and port matched head (nothing too crazy, ive had good luck porting my friends honda back in the day, and my motocross bike, just taking out the casting flash and making it match the mani/header, im going to have AMM do my final motor), and soon a mopar computer, new tires, quaife, aluminum flywheel
im gonna try 2 ways, if this doesnt work ill post the direct link
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i101.photobucket.com/player.s...L/100_1919.flv">
Old May 13, 2008 | 08:22 PM
TOOSTUBBORN2FAIL
Default RE: New Vid
http://s101.photobucket.com/albums/m...t=100_1919.flv
Old May 13, 2008 | 09:56 PM
TOOSTUBBORN2FAIL
Default RE: New Vid
should probably also clarify, this isnt the 15 second run, this was just a quick 1-3rd with my gf there on camera duty
Old May 13, 2008 | 10:28 PM
95to96transplantneon's Avatar
Default RE: New Vid
how about some vid's of your gf... lol jk
Old May 13, 2008 | 10:45 PM
neonracer1010's Avatar
neonracer1010
Default RE: New Vid
ORIGINAL: 95to96transplantneon
x2 without the jk part
do you need shifter forks?
Old May 14, 2008 | 05:58 AM
TOOSTUBBORN2FAIL
Default RE: New Vid
not, sure, cant tear it apart yet, my other cars down till i get that damn atx out of it, probably a month and a half before ill know, ill let you know tho, thanks
Old May 14, 2008 | 07:51 AM
neonracer1010
Default RE: New Vid
all ud hafta do would be stick ur arm down therre and see if u can wiggle them
Old May 14, 2008 | 09:21 PM
TOOSTUBBORN2FAIL
Default RE: New Vid
if your talking about where the cable ends connect to the shift arms on the outside of the tranny, theres not noticable play when its cold, it moves a little bit without shifting, but no more then a millimeter, however, the feel at the stick loosens up as the tranny warms up from driving
with the stock stick installed, theres about 1/8"-3-16" of play cold, and warmed up theres about 1/4"-5/16" of play
Old May 14, 2008 | 09:35 PM
Default RE: New Vid
I think he was talking about the fork...
Just take the dust shield off disconnect the cable and try to wiggle the fork...
it may be a streached clutch cable in witch case i have a easy solution that cost like 5 cents if that...
Damn it cant find the pic give me like 30 mins...
Old May 14, 2008 | 09:47 PM
Default RE: New Vid
ok here it is... my Zip tie trick...
1.) remove clutch cable from clutch fork.
2.) put large size zip tie on collor of clutch cable. the part that is about a half inch long that acually slides into the transmission.
3.) Re-install clutch cable...
walla new clutch cable... this will take out any slack you have in the clutch cable...as long as its not streached here to the moon...
