any one ever hook up there radio in the house
Old May 13, 2008 | 11:46 PM
neonracer1010's Avatar
neonracer1010
Default any one ever hook up there radio in the house
how would i go about doing it
Old May 13, 2008 | 11:53 PM
Neon_Freak's Avatar
Neon_Freak
Default RE: any one ever hook up there radio in the house
i hooked up my whole stereo system in my house just used a battery and a power converter and a battery charger. sounded nice and my neighbors hated me had 2 12's with 1100 watts to both of them
Old May 14, 2008 | 12:06 AM
95to96transplantneon's Avatar
Just take your car battery inside and connect teh yellow and red wires on the radio to the positive and the big black wire to the negitive... walla radio on...
Old May 14, 2008 | 12:23 AM
12 volt's Avatar
12 volt
all i use it a 120ac to 12DC voltage rectifier. the one that i have is only 8 amps so i can only hookup one headunit
unit the battery dies
Old May 14, 2008 | 09:57 AM
spudsterier's Avatar
spudsterier
i used to have 6-12's and 2-10's hooked up in my bedroom...until 1 of the windows broke out...then i moved most of it into my car
Old May 14, 2008 | 10:51 AM
vipersforsale's Avatar
vipersforsale
when I lived ina townhome a few years ago, I used to **** the neighbors off with a homebrew powered sub - 1-Kicker 18" sub and a Carver amp powered by a 150watt 12volt power supply. My bedroom was above their garage and they had a bad habit of using their garage as their front door at 2, 3, 4 am in the morning, up down up down, it was driving me crazy. So everytime they did that, since they slept during the day and their bedroom was on the other side of my living room wall where the stereo was... I would put on my bass test tone cd, one with the test tones at like 30Hz, then at 35Hz and then at 40Hz and so on and put the cd player on repeat and turn it up fairly loud and then leave for a few hours. And since I would have to remove all the pictures and stuff that would fall off shelves and such in my unit, I KNOW that their stuff was vibrating off the walls too. I only had to do this a couple of times before they stopped using their garage as their front door.
Old May 15, 2008 | 07:53 PM
neonracer1010
if i hook the yellow and red up directly to the battery, will i need any sort of adapter
Old May 15, 2008 | 10:54 PM
12 volt's Avatar
12 volt
ORIGINAL: neonracer1010
well youll need battery treminal connectors, butthe battery will die after about 20 min. Youll need a voltage rectifier if you want to plug it into your wall. i got mine from radio shack
Old May 15, 2008 | 11:16 PM
spudsterier
just hook the red and yellow wires together to the battery and then hook the black wire to the battery...then just throw a battery charger on it every once and a while
Old May 15, 2008 | 11:26 PM
neonracer1010
its all hooked up
my dad is pissed![8D]
