Question about Radio
Old May 14, 2008 | 10:07 AM
cpukramer's Avatar
cpukramer
Default Question about Radio
Hi all ... I am not the proud new owner of a 1998 Dodge Neon ... bought it yesterday and it is a nice, solid little car!! There are a few minor issues that need some fixing ... one of them is that the radio (its the OEM stock radio) only works on AM. I am assuming that there may or may not be an antenna problem, but I will investigate later. My question is: I have a stock radio from a 2002 Dodge Ram (my other vehicle) ... will that plug in directly as a replacement for this Neon radio? Basically its a CD player and its just sitting around so I'd like to install it if it will go in with no problems and look good. I appreciate any advice you can give!
Old May 14, 2008 | 11:37 AM
vipersforsale's Avatar
vipersforsale
Default RE: Question about Radio
not only do the plugs not fit, since they are not the same...but it wont fit in the hole either since its mounting points are on the sides instead of the way the OEM radio is on your neon
Old May 14, 2008 | 11:39 AM
cpukramer's Avatar
cpukramer
ok thanks for the info ... I guess I will have to see if I can get this one to work. It sounds like an antenna problem, doesn't it? The AM stations come in ok but FM all I get is static. I wish I had another radio to try with it to eliminate that possibility.
Old May 14, 2008 | 01:21 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Go to a wrecking yard and you should be able to get one cheap. I would have one to sell you if someone didnt steal my Pioneer deck out of my neon[:@]
Old May 14, 2008 | 02:25 PM
das2123's Avatar
das2123
Pull it out and look at the plugs to see if they are different. I don't know that they are. As far as the mounting tabs go, I had a radio from a 2002 neon in my 96. It technically wouldn't fit because of the mounting tabs (had 2 extra ones), but it wasn't anything that a dremel tool couldn't handle.
Old May 14, 2008 | 02:28 PM
cpukramer's Avatar
cpukramer
hmmmm ... ok sounds good I will check out the connectors tonight. That would be awesome if I could use the new radio. I'm sure I could figure out a way to mount it! I just hope that I can at least get the FM radio to work because I am dying listening to talk radio all the time!!!
Old May 14, 2008 | 02:31 PM
das2123's Avatar
das2123
ORIGINAL: cpukramer
Thats what I listen to mostly. Radio sucks....thats what CDs and MP3 players are for now
Old May 14, 2008 | 02:37 PM
cpukramer's Avatar
cpukramer
I agree with you 100% ... in my Ram I have Sirius Satellite Radio and an MP3 CD player ... if I EVER switch to terrestrial radio it is always to listen to the local AM sports station. In the Neon, however, I just got it and I am stuck with the bone stock AM/FM radio (no CD player or cassette) and the FM doesn't even work so I can't even use my Sirius, haha.
Old May 14, 2008 | 05:07 PM
vipersforsale
the plugs are totally different between the 2 radios, but pull it out to see for yourself. On top of that you will need an antenna adapter since the newer radios use the euro plug(must be the daimler influence?) You can buy a radio to wire harness adapter for the back of the newer radio and then a harness to wiring adapter for the neon and simply connect them together to make it work. But without modofication to the radio casing itself the newer radio will not mount intot he neon dash. If you so choose to use the radio later on in your truck such as for trade in, you will have to modify it once more to make sure it is solid enough in the dash.
Old May 14, 2008 | 08:07 PM
cpukramer's Avatar
cpukramer
ok well I pulled the Neon radio out of the dash and sure enough the connectors are different then the Ram radio. Thanks everyone for your help ... I will have to make a few calls to scrap yards and see if I can find a radio. I looked on eBay and stuff but they are all like $100. Worst case scenario I will buy the $40 autozone special and I can get the install kit and harness for $10 each.
