2.4 compression reading
Old May 17, 2008 | 10:55 PM
fsu182's Avatar
fsu182
Default 2.4 compression reading
what is a good compression reading on a stratus/caravan 2.4?
Old May 17, 2008 | 11:40 PM
95to96transplantneon's Avatar
Default RE: 2.4 compression reading
Compression[/b] should not be less than 689 kPa
(100 psi) and not vary more than 25 percent from cylinder
to cylinder.
Old May 17, 2008 | 11:51 PM
fsu182's Avatar
fsu182
ahh jeremy - always there whn i need ya. lol. so 120 psi is a good reading?
2.0 should test around 180 shouldnt it? why so much higher?
Old May 20, 2008 | 02:24 AM
yeah 120 would be a damn good reading... its just lower do to the stroke of the motor...
Remember the 2.4 has the same bore just an inch longer stroke... hence it pulls more air in every intake stroke... in theroy you would think extra air more pressure... however for some reason no...
Old May 21, 2008 | 02:51 AM
boxerjl2's Avatar
boxerjl2
sweet thank you guys.. i was gonna ask this before i do a compression check.. but i never got around to it..
