95 SOHC Crank Case Breather Delete, Possible?
Old May 22, 2008 | 01:10 PM
JackMehoffer69's Avatar
JackMehoffer69
Default 95 SOHC Crank Case Breather Delete, Possible?
I broke the old flimsy hoses off the crank breather on the 95 motor when I put my head gasket on. The head gasket stuck out too far into the breather and I moved it slightly over to make room for the head gasket and the old hoses that hold the breather on the block snapped off. Now I just want to get rid of that breather and use the stock 98 PCV system that uses the valve cover to intake breather.
My question is can I block those 95 breather holes off in the blockand use my 98 set up instead?
Old May 22, 2008 | 02:04 PM
12 volt's Avatar
12 volt
Default RE: 95 SOHC Crank Case Breather Delete, Possible?
yes, its the same thing just different location
Old May 22, 2008 | 02:22 PM
JackMehoffer69
Thank you very much, that will save me big time!
