Odd Oil Leak Somewhere???
Old May 22, 2008 | 11:29 PM
WRT's Avatar
WRT
Default Odd Oil Leak Somewhere???
Ok guys, I did a search but didn't really find anything in the area I am looking for!! I have recently started having an oil leak, When I first noticed it is when I would come to a stop I would see some smoke coming from the cowl, but if I had the air on I could smell burning oil in the car. Ok, now here is where I will try to explain where I am finding theoil. While standing at the drivers fender and look on the passengers side of the master cylinder, through the lines on the master cylinder and (I guess it would be the brake proportioning valves?!?!) You should be able to see what I am taking as the tranny bellhousing, there is a small puddle of oil on it, and there is oil on that side and the back of the engine. I reached in and wiped all the oil from the puddle on the bellhousing yesterday andthis evening I look in and see another small puddle of oil there.I have had nor can I find any oil in the coolant so I am thinking it is not the head gasket, and I can see most of the valve cover gasket(with the aid of a mirror) and can't see any tell-tell signs of oil leaking there, so any body ever had this problem or have any suggestions before I take it to a garage after the holiday????? There is also oil on the underside of the car and oil on the ground under the car, it seems to be going through about a quart of oil every 2 weeks or so!!! ANY SUGGESTIONS?!?!?!?!?!
Old May 22, 2008 | 11:42 PM
brushedchrome's Avatar
brushedchrome
Default RE: Odd Oil Leak Somewhere???
Take the car to a car wash and use the degreaser/tire cleaner in the engine compartment to get it all spick and span. Take it out and drive it a little to get the oil leaking again and look for its path. That way you dont confuse it with some strange accumulated gunk or other collected under the hood road goodies.
Old May 22, 2008 | 11:50 PM
95to96transplantneon's Avatar
sohc or dohc???
Old May 22, 2008 | 11:55 PM
WRT's Avatar
WRT
SOHC
Old May 23, 2008 | 12:05 AM
WRT's Avatar
WRT
Ok here are a couple of photos that MIGHT help!!!
These are where I was looking
The large circle is where the oil was before I cleaned it up and the small circle is where it was tonight
Old May 23, 2008 | 12:14 AM
switch the IMG to img and they will work... the img part needs to be lowercase... yeah its stupid i know...
Old May 23, 2008 | 12:34 AM
fsu182's Avatar
fsu182
my rear main seal wore out and had my structural collar looking like that - and my trans covered in gunked oil
Old May 23, 2008 | 12:45 AM
12 volt's Avatar
12 volt
Headgasket leaking oil?
Old Oct 14, 2008 | 02:39 PM
WRT's Avatar
WRT
Turned out to be the rear main, dosn't leak a drop now. Thanks guys!!
Old Oct 14, 2008 | 05:33 PM
FastNeon84's Avatar
FastNeon84
thats probably the FIRST place where neons start to leak oil.
your neon is hella clean. mucho cool points
