Intake
Wut intake would i use to route it to the front instead of it being right up against the header cause i see alot of pics with the intake going down by the battery box but wut intake do you use for it to get cooler air instead of hot?
you can go the junkyard and get a 90 degree elbow of a chrysler car with a 3.0 v6. that will allow you to put the air filter close to where you want it. you can also buy universal air intake tubing from the auto parts store. or you can rig up ur own tubing with w/e you want really. exhaust pipe.... w/e.
you will have to modify your battery tray to get a big enough tube down there as to not restrict airflow.
3.0 CAI
https://dodgeforum.com/m_833897/tm.htm
you can also do iceman and i think mopar sells one too
