What about nitrous?
Old May 28, 2008 | 12:16 AM
95to96transplantneon's Avatar
Default RE: What about nitrous?
here i found a nice setup... for cheap...
it uses a wot switch that you mount under your pedal or have your tb cam activate it at wot... but after reading a bit more the fuel is added and subtracted simply by the amount of vacume the manifold is creating more vacume more fuel less vacume less fuel... its more about the jetting of your fogger...
but hell for 363.88 shipped thats not bad...
http://cgi.ebay.com/ebaymotors/NOS-0...234763062&
Old May 29, 2008 | 08:17 PM
brushedchrome's Avatar
brushedchrome
Id be willing to spend the money on a nice setup. Would a MP PCM interfere with the nitrous? Man, makes me wish that I hadnt bougth that damn shotgun in the first place.
Old May 29, 2008 | 08:24 PM
yes it will interfear with the nos... it advances timing and you need the timing to be retarded... lol retarded...
Old May 29, 2008 | 10:13 PM
brushedchrome
Do the kits come with something to make the timing "retarded"?
Old May 29, 2008 | 10:35 PM
12 volt's Avatar
12 volt
ORIGINAL: brushedchrome
it shuld be fine with a OEM PCM,you really dont need to retard ignition timing as long as your not going over 150shot.
Old May 29, 2008 | 11:07 PM
brushedchrome
Cool. Then I guess I would be all set. Money money money.....
Old May 30, 2008 | 12:05 AM
acually if you run a 75 shot you retard 2* if you run 100 shot you retard 4*
Simple rule of thumb is 2* for every 25 increase in shot...
This is taken directly from an install guied from Zex and Nos has the same info...
Old May 30, 2008 | 12:11 AM
12 volt's Avatar
12 volt
with real world experiance as long as its not detonating you shouldn't pull out any timing. The more igntion time thats taken out is less powerthat you could betakeing advantage of.
Old May 30, 2008 | 04:11 PM
brushedchrome
Trial and error is sounding like the name of the game. With any luck, my shotgun will be sold here shortly and Neon goodies will be in the mail.
Old May 30, 2008 | 04:15 PM
12 volt's Avatar
12 volt
yup, just make sure its doesnt ping
page 17 talks more about ignition timing
http://www.nitroussupply.com/pdf/05130%20Wet%20kit.pdf
