What about nitrous?
Old May 30, 2008 | 04:38 PM
  #21
brushedchrome's Avatar
brushedchrome
Default RE: What about nitrous?
How do you adjust the timing on a Neon without buying and adjustable cam gear? Or is that going to have to be an added goodie?
Old May 30, 2008 | 04:44 PM
  #22
12 volt's Avatar
12 volt
only way to adjust cam timing is with a cam gear. this should only be done if your dyno tuning the car
Old May 30, 2008 | 05:50 PM
  #23
95to96transplantneon's Avatar
or if you have data logging capabilitys and are able to read them really well...
sorry 12 volt... had to do it...
Old May 30, 2008 | 05:56 PM
  #24
brushedchrome
Hmm. I guess I would really need to find out what happens when I put the squeeze on it. If it has problems, ill get the timing gear and find someone with a dyno to help with getting it squared away.
  #25
12 volt's Avatar
12 volt
whats that?
Old May 30, 2008 | 06:10 PM
  #26
12 volt's Avatar
12 volt
i wouldnt mess with cam timing, if anything ignition timing would be my main concern
Old May 30, 2008 | 06:26 PM
  #27
data logging is like what the lc-1 wideband is able to do or MS... hook your car up to a computer and find out what its doing... monitor your A/F ratio... if the A/F ratio is correct theres no detonation... So By monitering it over the coarse of a few runs you should be able to tell if your running lean and running into detonation...
Data logging maps sorta look like dyno grahps but should look smooth instead of a steady hill...
Old May 30, 2008 | 06:35 PM
  #28
12 volt's Avatar
12 volt
i dont think he has that capability
Old May 30, 2008 | 06:50 PM
  #29
probally not but if your running any type of forced indution incuding n2o you should have a wideband... period... might as well get one with data logging capabilitys... for a few more bucks...
heres one
http://cgi.ebay.com/ebaymotors/Innov...spagenameZWDVW
Old May 30, 2008 | 07:32 PM
  #30
brushedchrome
So, with this thing I should be able to adjust the ignition timing? Whatever it takes, ill do it. No short cuts.
