Replacing a Serpentine Belt
Old Jun 3, 2008 | 05:44 PM
redneckdaveabb's Avatar
redneckdaveabb
Default Replacing a Serpentine Belt
Anyone have a link or know how to replace a serpentine belt on a first generation Neon????
Thanks!
Old Jun 3, 2008 | 06:24 PM
95to96transplantneon's Avatar
Default RE: Replacing a Serpentine Belt
Neons do not have serpentine belts...
Are you talking about the power steering/ac belt or the alternator belt???
Old Jun 3, 2008 | 06:50 PM
redneckdaveabb
The alternator belt......
Old Jun 3, 2008 | 06:57 PM
Theres top and bottom bolt that goes threw the alternator bracket facing you as you stand on the passenger side of the car...you need to loosen those two bolts then theres a long bolt on the back of the alternator facing the firewall... turn that bolt and it will go forwards and backwards... so adjust the alternator forward slip the belt on then adjust the alternator backwards using the bolt... once its tight tighten the top and bottom bolts that go threw teh braket and your good...
Old Jun 3, 2008 | 09:21 PM
redneckdaveabb
It worked out well!
Thanks folks!
Old Jun 3, 2008 | 11:56 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
yeah its an easy pain in the *** lol
Old Jun 3, 2008 | 11:59 PM
yeah it is... Im small so i just jump up on the radiator support and put my knees on a towel thats over the valve cover and then reach back there...
Old Jun 4, 2008 | 10:36 AM
spudsterier's Avatar
spudsterier
ORIGINAL: 95to96transplantneon
technically, the alternator belt is a serpintine belt....
there are 2 different types of belts......V-belts and serpintine belts
a serpintine belt is just a flat belt
Old Jun 4, 2008 | 02:00 PM
12 volt's Avatar
12 volt
Serpentine belta single, wider belt instead of multiple, thinner belts
http://en.wikipedia.org/wiki/Serpentine_belt
