Mitsi/Neon
Old Jun 4, 2008 | 08:42 AM
moparmandjh's Avatar
moparmandjh
Default Mitsi/Neon
My son is thinking about buying a 97 Eclipse 2.0 dohc, is the drive train interchangeable with first gen Neons?
Dave
Old Jun 4, 2008 | 09:10 AM
das2123's Avatar
das2123
Default RE: Mitsi/Neon
Block is the same....thats all.
Old Jun 6, 2008 | 09:41 AM
Ghost Neon 2's Avatar
Ghost Neon 2
What are you referring to when you say "driver train?" The transmission, lash adjusters, lifters, etc?
Old Jun 6, 2008 | 10:44 AM
moparmandjh
Just wondering about engine, trans, etc.
Dave
Old Jun 6, 2008 | 11:36 AM
I_Ride_Neon's Avatar
I_Ride_Neon
You can use the lower end of the engine. The head is backwards and will not work on the neon. The tranny is way to big to fit into a neon and will not work without modification. So you can only use the block, brank, pistons. You will even need to use the sensors off you eclipse. and brackets.
Old Jun 7, 2008 | 02:36 PM
das2123's Avatar
das2123
ORIGINAL: I_Ride_Neon
brank
Is that what makes the Eclipse so fast
