exshaust leak again
Old Jun 4, 2008 | 06:59 PM
JDAWG901's Avatar
JDAWG901
Default exshaust leak again
i replaced manifold gasket donut gasket retightin everything still hear leak .could old o2 sensors be the problem
Old Jun 4, 2008 | 07:33 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: exshaust leak again
Could be. I have a great idea for you. Use sea foam in ur car. Then just watch for the smoke to come out.
Old Jun 6, 2008 | 09:55 AM
Ghost Neon 2's Avatar
Ghost Neon 2
New exhaust gasket + spray-on copper gasket + properly torqued exhaust bolts = fixed
*EDIT* is your exhaust manifold cracked?
Old Jun 7, 2008 | 07:36 AM
JDAWG901's Avatar
JDAWG901
YES BUT I REPAIRED IT . I SHOULD HAVE MENTIONED THAT IT ONLY LEAKS AT START UP AFTER I RUN IT A COUPLE OF MILES IT SEEMS TO GO AWAY UNLESS I ACCELERATE HARD
