Question
Old Jun 4, 2008 | 11:07 PM
FallnLord's Avatar
FallnLord
Default Question
would a 2.4 with Crane 18's would it be a nice match up for a 2.4 srt4 internals running like 3 to 10 poundS???
Old Jun 4, 2008 | 11:29 PM
95to96transplantneon's Avatar
Default RE: Question
ORIGINAL: FallnLord
some guys use 18's but you have to be damn good at tuning to get the a/f ratio right...
there is a better option thats cheaper... Brian Cower stage 3 cams...
http://cgi.ebay.com/ebaymotors/Brian...spagenameZWDVW
they have less overlap then the 18's and are all the rave for srt's... major gains...
And with srt-4 internalls you will be able to push crap loads more boost with the Brian Crowers then the Cranes due to lift and increased cranking pressure that the cranes produce... where the crowers keep the compression pressure down allowing more boost... Depending on what turbo your running... assuming the srt-4 turbofold, you will be able to run 18 - 20 psi and spike to 25 and be perfectly fine... as long as your fuel system has been upgraded...
