Front Passenger Window Problem
Well, it appears my trusty Neon is causing me grief (for the second time this week). Now the window is not sitting properly and when rolled up it sits forward
Could anyone give me direction on how to fix this problem???
Thanks!
Dave
Thanks!
Dave
I would take the door panel off and check the mounting of the window to the rails. The brackets are plastic and stamped "white metal", pretty cheap stuff. I've gone through two of the ones at the back (latch side) in my 97. If this is the issue, you might be able to find one in the junkyard, but if not, expect about $50 at the dealer.
