quick starter question
Old Jun 11, 2008 | 05:12 PM
fsu182's Avatar
fsu182
Default quick starter question
does the starter ground to the transmission? if it doesnt - can i ground it there? trans should be grounded through the engine right?
Old Jun 11, 2008 | 05:13 PM
fsu182's Avatar
fsu182
Default RE: quick starter question
1999
Old Jun 11, 2008 | 05:43 PM
brushedchrome's Avatar
brushedchrome
Dude, another starter question : What causes a starter to crank slowly? The battery is good, but the starter is weak acting. Bad ground?
Old Jun 11, 2008 | 06:01 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Ground wire from the battery hooks to the lower starter bolt when you put it in. For weak starts you need to check every connection for corrosion. Or for a bad connenction. Yes a bad ground can give you weak starts.
Old Jun 11, 2008 | 07:49 PM
95to96transplantneon's Avatar
I want to say the origingal ground strap for the starter went from the starter bolt to the fmm bolt... however I would go from the lower bolt to the drivers frame rail theres a few bolt holes for the battery tray... use one of those... better ground...
Old Jun 11, 2008 | 08:36 PM
das2123's Avatar
das2123
Attach ground cable to lower mounting bolt and start bolt.
Old Jun 11, 2008 | 09:09 PM
fsu182's Avatar
fsu182
got it. thanks. exhaust manfolds and exhaust need hooked up tomorrw. thats the last big thing. then some vac lines and hoses and fluid tanks.
what do i do with the vac lines that went into that thing that plugged into the egr since i blocked it off?
fsu182's Avatar
fsu182
by "that thing" i think i mean the EGR solenoid
Old Jun 11, 2008 | 10:49 PM
spudsterier's Avatar
spudsterier
go to autozone and buy a package of vaccum cap plugs..they come in different sizes and colors...then just remove all the unnecessary vaccum lines and put caps on them....
Old Jun 11, 2008 | 10:52 PM
fsu182's Avatar
fsu182
cool. i didnt even know autozone sold vac. cap plugs. thanks.
