SRT4 internals
Old Jun 12, 2008 | 10:36 PM
neon527's Avatar
neon527
Default SRT4 internals
will srt4 internals work on 98 2.0 DOHC?
Such as
-pistons
-valves & retainers
-Camshaft
I understand they might not be a direct bolt on, if i have to bore over i will, but jus the matter of it being compatible is my question? thanks!
Old Jun 12, 2008 | 11:15 PM
fsu182's Avatar
fsu182
Default RE: SRT4 internals
its not the bore - it'd be the stroke or compression that'd get you. the 2.4 has a longer stroke and a longer block. if u want to run srt internals then go to a 2.4. better off to keep ur own camshafts than go to srt's.
plus unless ur gonna turbo dont cuz srt stuff is low compression for boost.
Old Jun 13, 2008 | 12:19 AM
95to96transplantneon's Avatar
non of them besides the cams will work... and you will have to rotate the cam magnet... also you will get less power out of them..
Old Jun 14, 2008 | 06:34 PM
das2123's Avatar
das2123
Cams are compatible (not recommended though) and thats all.
Old Jun 15, 2008 | 12:07 AM
spudsterier's Avatar
spudsterier
you cant put 2.4 internals in a 2.0....there is a reason its a 2.4
Old Jun 15, 2008 | 01:29 AM
to give you a direct answer to why the 2.4 has a 1 inch longer stroke... witch would pound the piston into the head...
Old Jun 15, 2008 | 01:04 PM
neon527's Avatar
neon527
thanks for the info guys, as always much appreciated!
