HOW change my front tie rods,and Struts....??
Old Jun 18, 2008 | 11:50 PM
reppinthe202's Avatar
reppinthe202
Default HOW change my front tie rods,and Struts....??
How do i change these
a nice how to would be nice
i havent did this be4 so easy to follow directionswould be nice
Old Jun 19, 2008 | 12:08 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: HOW change my front tie rods,and Struts....??
Its really straight forward. Tie rod end. You will loosen the bolt the holds it to your hub assembly. Then break loose the nut that holds it tight. Count the number of turns you pull it and put the new one on the same number of turns. Struts. Remove the nuts from the lower part of the strut. Then tap out the bolts. Take off the brake line bracket with a 10 mm. And take the 3 nuts off the top of the strut. Before you do that you will need to jack up the car and pull the tire.
Old Jun 19, 2008 | 07:47 AM
mulletman11's Avatar
mulletman11
when installing new struts or springs, do u need to compress them?
how about changing a control arm?
Old Jun 19, 2008 | 02:09 PM
12 volt's Avatar
12 volt
supension how to
http://www.autozone.com/addVehicleId...00c15280079664
control arm
http://www.autozone.com/addVehicleId...00c15280079538
or buy a haynes and [sm=icon_rtfm.gif]
