Installing the ATX throttle body guide?
Old Jun 24, 2008 | 11:32 PM
protivakid's Avatar
protivakid
Default Installing the ATX throttle body guide?
Hey,
I was looking through the FAQ's and never saw a guide. It seems easy enough I just didn't know if there was anything in particular to look for. My MTX has cruise control and so does the auto I got it off of but it looks as if I have to take apart and swap over the part where the wires connect on my MTX TB anyways. Any other tips? Thanks.
~Christopher
Old Jun 25, 2008 | 12:40 AM
mmench's Avatar
mmench
Default RE: Installing the ATX throttle body guide?
1. unbolt old tb
2. take off sensors (if you have a sohc and the new tb came from a sohc you can use the sensors from new tb aswell)( if you are mismatching from sohc to dohc or vice versa the sensors are a lil different i beleive.. so you will have to reuse old sensors)
3. since bopth are from a cruise control car you dont have to take off the part the cable goes to.
4.bolt on sensors you need to use to tb
5. bolt on new tb to manifold and hook up acessories
6. done
7. im stoopid so if i miss anything .... oops
Old Jun 25, 2008 | 12:57 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
what about tools needed? I just did mine the other day and I dont remember what tools I used. I do know that I put a purdy new 55mm TB with a Iceman intake though (thanks spud I finaly got to use it)
Old Jun 25, 2008 | 01:24 AM
mmench's Avatar
mmench
you need some torx bits for the sensors. a ratchet and extension for the bolts holding down the tb. and thats is lol.. i dont remember wat sizes
Old Jun 25, 2008 | 01:30 AM
DOHCgarrett t3
I think its 10mm. the torx I have no idea, trial and error there.
Old Jun 25, 2008 | 07:30 AM
mulletman11's Avatar
mulletman11
yea i belive ten and 2 8mm bolts that go in sideways somewhere
extensions are a must, or ur gonna cut up your hands
