oil in spark plug holes???
RE: oil in spark plug holes???
Its the spark plug seals. There are 4 of them. Not the valve gasket cover. But you will need to pull the cover to change them. You will also need a new valve cover gasket in the process. Dont use sealant if you buy a new gasket. Thats the point of the gasket.
ok lets not get technical, wen u go to buy a valve cover gasket does it come w 4 new spark plug hole gaskets, yes!
so tis ur valve cover gasket components leaking.
sorry didnt want to spell out spark plug hole gasket ring, figured wen he got the new gasket he would not use the old ones
and yea i would use rtv, always have and have never had a problem
ORIGINAL: mulletman11
