SPEED SENSOR
Old Jun 25, 2008 | 07:29 PM
JDAWG901's Avatar
JDAWG901
Default SPEED SENSOR
HOW CAN YOU TELL IF YOUR SPEED SENSOR IS GOING BAD
Old Jun 25, 2008 | 09:09 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: SPEED SENSOR
Usually they get a little moisture in them. Cleaning it out and playing with the plug to make sure its snug could be a good start. Did you change the cluster already?
Old Jun 26, 2008 | 08:56 AM
spudsterier's Avatar
spudsterier
sumtimes its hard to diagnose between a bad speed sensor and a bad gauge cluster....
if your speedometer just stops working, then it could be either one
Old Jun 28, 2008 | 01:26 AM
das2123's Avatar
das2123
If the speed sensor is bad, the odometer won't work either.
Old Jun 28, 2008 | 02:04 AM
XenonNeonSport's Avatar
XenonNeonSport
das2123: My speedometer doesnt work half the time either, and when it doesnt work, the Odometer doesnt. I replaced the speed sensor and it didnt help. Its a waste of money ($60)...and a pain in the rear. I would recommend having the "Ratchet Wrench". It takes an 8mm, if you MUST replace it...
Jdawg: Id take off the gauge cluster and get to the circuit board. If you have access to a soldering iron, there are two points you need to solder. Name:  solderpoints.jpg
Old Jun 28, 2008 | 08:40 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Man, this lady is quick! Good post.
Old Jun 29, 2008 | 01:45 AM
XenonNeonSport
Thanks Ghost I know alot more than the average chick lol
