over heating or what?
i have a 96 dodge neon 4d it will drive fine for about 8 miles an the it cuts off like its overheating but the thermostat shows the heat lvls are fine, i have changed the thermostat and checked all my fluids yet no luck
any ideas?
any ideas?
Your Coolant Temperature Sensor may be bad if it is truly overheating and not showing up on the gauge. As to the overheating...are your fans turning on? My car started overheating cause the fans were turning on, but not when they were supposed to. It turned out to be the Cooling Fan Temperature Switch. Try making sure there's no air in your cooling system. Is it leaking any where or showing any codes?
