this is a question for 95to96transplantneon
Hey man I like ur how to post for 2.4 but u didn't say anything bout the axles.. Alsowit all those other parts none of the 2.4 parts well fit in the neon... if u can r have aim hit me up (sppneon)
You use the same axels that came out of the car... as long as you are using the same type transmissino you did before... ie mtx ATX they the passenger side is the same but the ATX drivers side axel is shorter then the MTX axle...
if you had a MTX and using a MTX use the same axles
if you had a ATX and using a ATX use the same axles
if you had a MTX and using a ATX need a ATX drivers side axel
if you had a ATX and using a MTX need a MTX drivers side axel
