Fwd newbie but dodge lifer
Old Jul 8, 2008 | 11:27 PM
Bigrmopar's Avatar
Bigrmopar
Default Fwd newbie but dodge lifer
Hi newbie here just picked up a 96 4dr Neon to save on gas paid for by scraping my nearly 400,000 mile Ramcharger 4x4[]. Have always owned dodges and always will( also own 78 Magnum t-top 360). anyway details on the neon - sohc atx 102,000 miles pretty nice shape overall just replaced all brake lines, fuel lines, sending unit, pads/rotors, and shoes. Plan on head gasket and timing belt in near future but is there anything else that i should look into as a common problem?
Old Jul 9, 2008 | 12:06 AM
spudsterier's Avatar
spudsterier
Default RE: Fwd newbie but dodge lifer
when you replace the head gasket and timing belt, also replace the timing belt idler pulley and the water pump....other then that, you should be good to go
Old Jul 9, 2008 | 09:53 AM
neoncrazy101's Avatar
neoncrazy101
ORIGINAL: spudsterier
isn't that only on the DOHC?
Old Jul 9, 2008 | 02:15 PM
das2123's Avatar
das2123
^^^Nope, thats on both.
Old Jul 9, 2008 | 03:30 PM
Bigrmopar's Avatar
Bigrmopar
thanks
took a closer look today at the motor and noticed a MLS head gasket so does that mean it has already been done?
Old Jul 10, 2008 | 08:33 AM
das2123's Avatar
das2123
ORIGINAL: Bigrmopar
thanks
Yes it does, so you should be good.
Old Jul 10, 2008 | 10:00 AM
spudsterier
ORIGINAL: neoncrazy101
same thing for the sohc and dohc, but the dohc has 2 idler pulleys (1 idler and 1 timing tensioner) and the sohc only has 1 (tensioner pulley)
