I need dohc cam sensor, pig tail for the cam sensor, dohc spark plug wires, and dohc water outlet that goes on the intake manifold, 96 dohc wire harness, dohc idler pulley. And I think the sohc tensioner is the same? Thanks!
RE: WTB: Dohc cam sensor, 96 dohc harness, and more
Idle pulley is the same. The pig tail is a pretty common connector found all over 2G four cylinder dodges ( coil pack , speed sensor, crank position sensor, and maybe somewhere else).
i have a cam sensor (about a dozen actually) along with a pig tail, dohc MSD 8.5mm plug wires (used for about 300 miles) and the water outlet(if your talking about the thermostat housing)
