throttle body
Old Jul 15, 2008 | 05:41 PM
denverneon1's Avatar
denverneon1
Default throttle body
I was wondering if I should install the throttle body from an automatic tranny equiped neon, to my manual tranny equiped neon? I did some research and the atx throttle body is slightly wider. If so would i have to modify my intake manifold in any way?
Old Jul 15, 2008 | 05:59 PM
12 volt's Avatar
12 volt
Default RE: throttle body
no, you my have to swap senors
Old Jul 15, 2008 | 08:10 PM
das2123's Avatar
das2123
ATX TB is 52mm vs the MTX TB that is 49mm. It is a direct and easy swap. The biggest difference you will notice will be the ability to rev quicker because of the "touchy" spring feel from the ATX TB.
Don't expect big HP gains.
Old Jul 15, 2008 | 11:11 PM
chenzo's Avatar
chenzo
alright fellas, while we are on the topic of throttle bodies, i need some help, on a problem that has been pissing me off for some time cuz i cant figure it out.
ok. i bought a ATX TB from Zach, and it looks like this:
and the one on my car looks like this:
so am i just dumb as a box of rocks and those are the same and will work? or can i make them work? or am i F*****? thanks.
Old Jul 15, 2008 | 11:16 PM
I_Ride_Neon's Avatar
I_Ride_Neon
So wait one looks like < and one looks like this >
Old Jul 16, 2008 | 08:50 AM
das2123's Avatar
das2123
Can you get a clearer picture of the one you bought?
Old Jul 16, 2008 | 09:31 AM
neoncrazy101's Avatar
neoncrazy101
Das, the ATX TB with Cruise. where the cruise cable hooks up to is just like where the cable for the kick down cable. its that pushed on snap on type cable.
Old Jul 16, 2008 | 10:09 AM
spudsterier's Avatar
spudsterier
the throttle body you bought is from a 95/96 neon, the throttle body you have is from a 97-99 neon...
the clip styles for the cruise control were changed in about late 96....
so to fix the problem, you have to either change the butterfly shaft or get a new cruise control vaccum actuator
Old Jul 16, 2008 | 10:13 AM
das2123's Avatar
das2123
^^^There you go....from someone who has more parts than autozone for the neon
Old Jul 16, 2008 | 10:17 AM
spudsterier
ORIGINAL: das2123
haha..
i just remember running into this problem in the past...
thats why whenever i sell a throttle body, i usually ask if they need the 95/96 style or the 97-99 style
