will this really work?
Old Jan 25, 2005 | 01:47 AM
GroundControl's Avatar
GroundControl
Default will this really work?
Hey i was searching around and ran across this web site> www.20horsepower.com
check it out and tell me if you think its true and will work. It sounds correct but, Its cheaper then buying a performacne pcm. There are review on it but,how can i tell if there true.
Old Jan 25, 2005 | 04:13 AM
ewetho's Avatar
ewetho
Default RE: will this really work?
Well it seems they are installing it into the 02 sensor and thus theoretically possible I guess. But with OBDII you do need to have the Fuel/Air ratio to cycle rich then lean known as 02 switching (Will stop on certain occassions to allows certain things) which allows the elements of the CAT to work effectively. So this product would not allows for the cat to work properly i would imagine.
Down side is you could melt a cat if ran rich too long and this what it is doing. Would not be as safe as a Chip which could monitor your driving habits as well as engine requirments.
Just in case your wondering the cat will store excess oxygen when the F/A is lean and then pumps it back out when the F/A is rich to burn off the excess fuel. This is part of the new catalysts to control NOX as well as earlier controlled gasses such CO and HC.
Old Jan 25, 2005 | 07:11 AM
casper's Avatar
casper
it is no different than the 20+ hp adders on ebay. Can you say bull ****!!!!!!!!!!!!!!!
Old Jan 25, 2005 | 12:08 PM
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
ha ha
