need to change front brake caliper
Old Jul 20, 2008 | 08:48 PM
naturallyaspirated's Avatar
naturallyaspirated
Default need to change front brake caliper
i need to change my front left brake caliper. ihave a general idea how to do it but i dont want to take any chances with brakes. if anyone could give me some instructions on how to do this that would be awesome. thanks
Old Jul 21, 2008 | 12:53 AM
neonracer1010's Avatar
neonracer1010
Default RE: need to change front brake caliper
take the 2 10mm bolts off the caliper that hold it to the steering knuckle and then there is another bolt i belive its a 13mm but not to sure take that off then reverse process
then bleed your brakes and ur done!
Old Jul 21, 2008 | 01:11 AM
12 volt's Avatar
12 volt
http://www.autozone.com/addVehicleId...00c152800796ea
bleeding the brakes could need two people and is the most important part.
Old Jul 24, 2008 | 10:52 AM
unclemike's Avatar
unclemike
Spend the money for a Haynes manual, if you plan on doing your own work it will pay for itself. Also consider replacing both calipers at the same time. If one is bad the other might be going too. As long as you have it apart check both sides of your rotors and replace if necessary.
Old Jul 25, 2008 | 02:36 PM
das2123's Avatar
das2123
ORIGINAL: 12 volt
Thats why I love my speedbleeders.
Old Jul 26, 2008 | 11:25 AM
neonracer1010
ORIGINAL: das2123
ORIGINAL: 12 volt
what are those
Old Jul 26, 2008 | 02:03 PM
I_Ride_Neon's Avatar
I_Ride_Neon
http://speedbleeder.zoovy.com/ the act like a one way valve when pumping the brakes.
Old Jul 26, 2008 | 09:53 PM
das2123's Avatar
das2123
ORIGINAL: neonracer1010
ORIGINAL: das2123
ORIGINAL: 12 volt
what are those
They are freaking great to bleed brakes. Worth the money without a doubt.
