wats da recommendation of timing belt change on 97
Old Jul 22, 2008 | 05:32 PM
contagious19's Avatar
contagious19
Default wats da recommendation of timing belt change on 97
is it da same like my 00? . i might pick up a 1st gen as a new toy
Old Jul 22, 2008 | 05:42 PM
fsu182's Avatar
fsu182
Default RE: wats da recommendation of timing belt change on 97
i wouldnt let it go much past 80 - 90 k. my car was babied as a newborn and somehow made it to 212k on a stock timing belt and head gasket. but when the belt broke - it took all but four valves with it.
Old Jul 22, 2008 | 07:12 PM
contagious19
damn
Old Jul 26, 2008 | 07:29 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Changed ever 60k s the factory spec. Depends on the driver somewhat. Are you a gambler...?
Old Jul 31, 2008 | 03:57 AM
contagious19
yea. lol.
Old Jul 31, 2008 | 09:18 AM
das2123's Avatar
das2123
Timing belt, water pump and idler pulley should be changed every 100,000 miles.
Old Aug 1, 2008 | 03:24 AM
contagious19
my 00 is currently going through dat. well c wat 1st gen ill get
Old Aug 1, 2008 | 09:48 AM
das2123's Avatar
das2123
Try to stick to the 97-99 1st gens if you can. They have more common engine sensors than the 95 and 96.
Old Aug 2, 2008 | 03:53 AM
contagious19
well i might get a 98 r/t depending on a guy dats looking at it
Old Aug 3, 2008 | 09:34 PM
unclemike's Avatar
unclemike
Just did my daughter's '96 Highline coupe at 98K. The water pump went out, the belt looked good but it had been replaced by the previous owner. New pump (no rebuild junk) and idler pulley. I got an assortment of 12x1.75mm bolts to make the process of removing and installing the balance easier.
