Leaking
98 neon seems to be leaking a brown liquid, my guess is it's either tranny fluid or brake fluid. Wondering if anyone would have an idea wat could be the problem. Don't think it's the head gasket because it was replaced earlier this year. If it is the head gasket again im done with my neon.
Where is the leak in relationship to the car? Did you look under the hood at all and check things like your master cylinder and inspect for leakage? Need more help then brown stuff from the car. May be just a valve cover gasket (Easy) or if you had an oil change recently possible oil change person missed. So please take a quick look around and give us a few more clues!
My car had been leaking brown stuff for the past couple of days but it was just dirty snow melting.
Don't know how the weather is there, but clean the motor with a degreaser, then try to find out where its comming from. If its oil, powersteering, Transmission, brake, if its major you will see the fluid levels going down. are you losing any fluids?
