p0137
Old Jul 31, 2008 | 12:01 AM
candy's Avatar
candy
Default p0137
p0137 HOW DO I FIX THAT? everyone keeps tellin me its a o2 sensor but what is that where is it and how do I fix it whats it gonna run me? And I got a p0303 and I was told that it could either be spark plugs or spark plug wires but I just changed both of them about a month ago so what else could that mean?
Old Jul 31, 2008 | 01:13 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: p0137
If the code is for the o2 its a bad o2 sensor... there are 2 on the exhaust. One on the header and one down before the cat. I assume the second code is for a missfire. I dont want to look them up right now. If u changed the plugs are wires then you should be good. Just clear the codes out after you fix them.
Old Jul 31, 2008 | 09:21 AM
das2123's Avatar
das2123
Default RE: p0137
P0137 Downstream O2 Sensor Voltage Shorted To Ground
P0303 Misfire Cylinder No. 3
