overheating
my 95 dodge neon sohc has been overheating but ive had the headgasket, waterpump, and thermostat replaced. it only does it when my a/c has been running for awhile. it still has coolant in the radiator and resevoir. any help would be greatly appreciated.
the radiators on these cars have a problem after some time with the cooling fins deteriorating away and causing over heating problems.....best way to chesk is to unbolt the fans from the radiator and pull them back a little bit so you can get a clear look at the radiator...specifically the lower corners....make sure the fins are all there and in good shape
Trending Topics
i got a new question now that its not overheating anymore!!! What kind of mods can i do to give my car some more speed or more importantly to me, more acceleration? nothing like a turbo or nos, jus cheap mods?
under drive pully, cold air intake and the list goes on.
read these
http://halfahemi.com/fastatx/
http://www.allpar.com/neon/performance.html
http://www.angelfire.com/trek/iraya/...erformance.pdf
https://dodgeforum.com/forum/1st-gen-neon/35626-how-do-i-make-my-1st-gen-neon-faster.html
read these
