toggle switch
Old Aug 4, 2008 | 11:57 PM
neonracer1010's Avatar
neonracer1010
Default toggle switch
ok so i have a toggle switch for my fans
there is an accessory for a lite
where would i hook that up to
and another question can i hook my laptop up to the radio somehow?
Old Aug 5, 2008 | 01:41 AM
12 volt's Avatar
12 volt
i guess the accessory is for the switch to light up, if thats the case yuo could wire into you cabin light. Instead of useing a toggle switch you should try useing a thermal switch for the fan on.
The factory radio cannot hook up to a laptop. You could possibly if you have an aftermarket unit.
Old Aug 5, 2008 | 01:50 AM
neonracer1010
whats a thermal switch, i havea toggle so my fans run all the time because only haf of my radiator flows
Old Aug 5, 2008 | 02:19 AM
12 volt's Avatar
12 volt
this link expains different ways for an automatic turn on.
http://www.the-fan-man.com/info/setu...-switches.html
Old Aug 5, 2008 | 09:02 AM
spudsterier's Avatar
spudsterier
what would you need to hook your laptop up to the radio for?
Old Aug 5, 2008 | 04:23 PM
12 volt's Avatar
12 volt
if your headunit has an input you can use a 3.5mm male to RCA cable, and that will play music from your laptop or anything that has a 3.5 jack.
somthing like this
http://www.yourcablestore.com/35mm-S..._p_17-121.html
Old Aug 5, 2008 | 05:06 PM
spudsterier
yeah but why not just get an mp3 player?
Old Aug 5, 2008 | 10:52 PM
neoncrazy101's Avatar
neoncrazy101
when i hooked up my toggle switch for the fans it went as so
Positive terminal: power in.
Acc: goes out to fan.
Negative: ground (negative battery terminal was the only way i could get it to work)
Old Aug 5, 2008 | 11:03 PM
neonracer1010
i have an i pod but i just dont like going threw all the music on there and its just a pain in the *** using the radio turner for i trips
Old Aug 10, 2008 | 12:49 PM
neonracer1010
could i just plug that rca to headphone into an amp preout?
