cold air intake
Old Aug 5, 2008 | 02:39 PM
bjsharp85's Avatar
bjsharp85
Default cold air intake
Hey guys. I have a 98 r/t. i have had it for a couple months.. im trying to see how guys are mounting the cold air intake down by the battery box. the one i have has it going back where the old air filter box was.. can anyone tell me what kinda cold air intake or where to get the parts for it. cause im not figuring it out.. thanks guys
bjsharp85's Avatar
bjsharp85
Also I have not done anything to this car yet.. Anyone got any ideas.
Old Aug 5, 2008 | 02:48 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
look up 3.0 intake or get yourself an Iceman intake be forewarned The Iceman is not cheap.
Old Aug 5, 2008 | 03:06 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Or you can relocate you battery and make your own cai.
Old Aug 5, 2008 | 07:22 PM
l33tn3wb3r's Avatar
l33tn3wb3r
It's easy man. I bought a cheap one off of eBay. If you're going to be serious about modding your car, go Iceman, otherwise get a cheap one off eBay for like 30-40 bucks. You will have to mod your tube a little bit. First things first, you will need a 90 Degree rubber elbow that fits around the mouth of your intake. I forgot how big it is, but make sure it's thin, you don't want a thick one. The 90 degree allows your tube to tilt down towards your battery. Figure out how much you need to cut off so that it goes straight down and under your battery. No battery relocating and minimal effort
Old Aug 5, 2008 | 07:39 PM
fsu182's Avatar
fsu182
i got a spectre air filter, and spectre collapsable tubing straight from autozone. I removed the battery cover, and battery temp sensor. Then I got a bolt cutter and used it to snap away parts of my batter box till the tube fit. I tucked the temp sensor in around the headlight housing, used the 3.0" to 2.5" adapter that came with the tubing and bam. no more snorkel. i even use an oversized battery.
