just to be clear??
ok i have a few more questions for anybody with srt turbo know how.
#1 will removing the lines from the tb (the ones that go to the left side of the car to the cylinoid and canister) hurt anything? i dont think it does but just being cautious
#2 i have my BOV vacume line connected rite to the TB..... under vacume is the BOV supposed to be open?
#3 were can i T in my water temp sensor... i think i read somewere that you could use a port on the back of the block???
#4 i see on the begi website that they say you need to run the stock regulator in suport of the rrfpr. i believe in is the 2027 model. now i am goin to do the spoolboy mod and bypass the stocker and add a return line. will this still be fine?
#5 and finally ... .WHY THE HELL DIDNT DODGE MAKE A TURBO FIRST GEN? they are fun as ****
#1 no it wont hurt anything, but you will want to remove the rubber o-ring on the inside of your gas cap...otherwise the vapor pressure can cause damage.
#2 the blow off valve will open under cavvum pressure...thats how it releases..and it will close once positive pressure is made
#3 there is a port sumwhere, but i cant remember where...you could also use a port on the side of the head, but im not sure which one...or you could put a T fitting in the heater hose
#4 you shouldnt NEED to run the stock regulator, but im not exactly sure...i ran through the stock regulator without any problems though...just had the canister modified for the return line
#5 because they were dumb....
how much boost you gonna run? if anyone thinks low boost in a 1st gen is fun, try 18psi....its just crazy
thnx man .. i just had to make sure... was tired as hell and couldnt remember anything. did you have any problems adjusting idle fuel pressure with your begi? i am running the stock stage 0 fuel injectors (stage 0 i beleive atleast) and they run WAY to fat at idle and no boost lol..i plan on just running 10 pounds of boost... but if i hear a knockin.... you can bet im gona turn it up as far as she goes and let her rip
