Problem wiyh my 97 neon
Old Aug 24, 2008 | 04:40 PM
wesj1211's Avatar
wesj1211
Question Problem wiyh my 97 neon
Hello everyone. I have a problem with my neon 97. I want to know how i resolve the problems. The Codes are: P0123 TPS/Pedal Position Sensor A Circuit High Input, P0118 EngineCoolant Temp Circuit High Input, P0113 IAT Sensor 1 Circuit High Input. I really apreciate any help. Thanks
Old Aug 24, 2008 | 10:17 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! I'll move you to the Neon Section.
Dusty
Old Aug 26, 2008 | 10:48 AM
das2123's Avatar
das2123
Is your car overheating?
Old Aug 27, 2008 | 09:43 AM
wesj1211's Avatar
wesj1211
Thumbs up
Yes. My car is overheating. The fans not turning on. Im already install the coolant sensor and the car worked well for two days. But now the car have the problem again and the three codes.
Thank you very much for try to help me ¡!¡!
Old Aug 27, 2008 | 09:49 AM
das2123's Avatar
das2123
Check the fan fuse and relay.
Old Sep 3, 2008 | 10:20 AM
wesj1211's Avatar
wesj1211
I'm checked the fan fuse and relay and its ok. But the fans dont turn on. I dont know what is the problem. I do everything and the fans dont turn on. . Please help¡¡¡¡¡¡¡
Old Sep 3, 2008 | 10:42 AM
das2123's Avatar
das2123
How did you verify the relay is good?
Old Sep 9, 2008 | 05:54 PM
wesj1211's Avatar
wesj1211
Im verified with a voltimeter with the car on and off. The voltimeter show the correct voltage. Now I ask you which relay I need to verify? Because I verified the fan relay in the PCM. Thanks for all buddy. Im very
Old Sep 9, 2008 | 11:44 PM
das2123's Avatar
das2123
Have you tried running a wire from the battery to the fans to verify the fan motor works?
After that...test the wiring between the PCM and the radiator fans by disconnecting the PCM connector C2. Momentarily ground pin 18 of the connector, not the PCM. Radiators should turn on right away. You don't need the ignition on at all as this circuit is always hot.
