98 Neon alternator
Old Jan 31, 2005 | 11:07 PM
whitedogdaddy's Avatar
whitedogdaddy
Default 98 Neon alternator
Just replaced 2.0 DOHC in 98 Neon. Used the alternator from the old engine. It worked fine before but it doesn't charge now. All connections look good to me. Did I miss something?
Old Jan 31, 2005 | 11:59 PM
casper's Avatar
casper
Default RE: 98 Neon alternator
If it worked fine before and now it does not, chances are you missed something. Bring it to autozone and have it tested to make sure, but its unlikely that its bad if it worked before. check for loose or disconnected wires, thats most likely the problem.
